10-13-2007 05:02 AM - edited 03-14-2019 11:56 PM
I'm not sure I can do the auto attendant functions on CCM4.1(3) without any servers.
Thanks in advance.
Thot
Solved! Go to Solution.
10-13-2007 06:31 AM
Hi Thot,
This is possible with CCM 4.1(3) Have a look;
Cisco CallManager AutoAttendant
Cisco CallManager AutoAttendant, a simple automated attendant, allows callers to locate people in your organization without talking to a receptionist. You can customize the prompts that are played for the caller, but you cannot customize how the software interacts with the customer.
Cisco CallManager AutoAttendant comes bundled with Cisco CallManager on the Cisco CallManager Extended Services CD. This version of Cisco CallManager AutoAttendant provides a four-CTI port limit. If you need a fully configurable automated attendant, you will need to purchase Cisco IP Interactive Voice Response (IP IVR), one of the Cisco Customer Response Applications (CRA).
From this good doc;
Nice post from Mahesh;
Hope this helps!
Rob
10-13-2007 06:31 AM
Hi Thot,
From this good doc;
Hope this helps!
Rob
10-13-2007 08:52 AM
Hi Rob.
Thanks for informations. you are a nice guy as usual. I give you 5! ;-)
Thot
10-13-2007 09:05 AM
Hi Thot,
Thanks for your very kind words :) I am glad that I could help in some small way!
Take care and best of luck,
Rob
