compression
Oct 13th, 2007
I'm running into a problem here I'm trying to take off compression on a serial interface. I do the "no" form of the command on the remote router but then when I do the same on the local router I can no longer log back into the remoter router. I've done 2 other routers successfully just this one is giving me problems. Any advice would be greatfully appreciated...Here is the config on the remote end:
interface Serial0/0
ip address 172.19.98.198 255.255.255.252
ip accounting output-packets
ip nat inside
encapsulation frame-relay
no ip route-cache
ip ospf network point-to-point
no ip mroute-cache
fair-queue 64 256 0
service-module t1 timeslots 1-8
frame-relay map ip 172.19.98.197 16 broadcast IETF payload-compression FRF9 stac software
frame-relay lmi-type cisco
Thank you in advance
royalblues Sat, 10/13/2007 - 05:11
  • Green, 3000 points or more
What exact command are you negating..
You only need to remove the compression but you would still require the MAP statement
Narayan
