Monitor Individual Switches in a Switch Stack
Answered Question
Oct 13th, 2007
Does anyone know how monitor individual switches in a switch stack?
Correct Answer by jreekers about 9 years 4 months ago
Hi. The best way to go about this is by use of the CiscoStackWiseMIB. I'll show you an example. Go here:
http://jaguar.ir.miami.edu/cgi-bin/snmptransc.cgi
and in the "Object Identifier or Object Name" box, put .1.3.6.1.4.1.9.9.500
Select "tree translation" and you'll see all of the MIB objects this MIB supports.
Other good info:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_white_paper09186a00801b096a.shtml
(stackwise white paper)
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/prod_bulletin0900aecd803fdbd8.html
(search for "stackwise")
Or just do a search on CCO for "Stackwise" or "Stackwise MIB" and you'll find many results.
HTH,
-J
Overall Rating: 4 (3 ratings)
Correct Answer
jreekers Sun, 10/14/2007 - 18:21
Other good info:
HTH,
-J
yuchenglai Mon, 10/15/2007 - 06:03
J,
This is exactly it!! Thanks! But I think the link at miami.edu is not working.
