IP Phone Agent in HA environment
Answered Question
Oct 13th, 2007
We have IPCC 4.05a.
To use IPPA in an HA environment will I need to create 2 IP services in CAll Mgr.? 1 service pointing to each server?
Or is there a service that can be used that will try server A then server B?
Trae
Correct Answer by Dennis Fogler about 9 years 4 months ago
Trae,
You are correct, you will need to create two IP Phone Services within Call Manager; 1 service pointing to each UCCX server.
I have seen some attempts to use DNS or server load balancing to get around this; however, at the end of the day configuring two services seems to work the best.
Overall Rating: 5 (1 ratings)
Correct Answer
Dennis Fogler Sun, 10/14/2007 - 09:16
Trae,
cairns-a Mon, 10/15/2007 - 05:29
Thanks. I thought we would have to create a new service or change the current one to the other server if we needed.
Trae
