ASA VPN - NAT Peer network
Oct 13th, 2007
We have a requirement to NAT every site-to-site VPN host into a specific range of IPs. For example, A remote host is 10.1.1.200, we need to NAT this on our ASA to 172.24.202.1 through to the destination network.. This needs to be a 1-to-1 static nat for inbound and outbound communication to our network. Does this only require a static (inside,outside) along with static (outside,inside) or is there more that is needed? Any help is greatly appreciated.
thefindjack Mon, 10/15/2007 - 11:05
You will have to do a static translation for each one or you can use a nat-pool. Static (inside,outside) works both ways, there is no need for the (outside,inside) you are refering to.
Please rate if this is helpful. Thanks
You can also do a policy static for this. This allows you to statically xlate to a specific IP for certain traffic then use a NAT/Global pair for everything else.
Example:
access-list pnat extended permit ip host 192.168.1.1 host 172.16.1.1
static (inside,outside) 10.1.1.1 access-list pnat
nat (inside) 1 0 0
global (outside) 1 interface
Jay
