I need to Manually set the VPN Client Time Out Limit.
Oct 13th, 2007
How do I increase Time Out setting. Right now it seams to disconnect after about 30 minutes. I would like it to stay connect longer for a select few users. Thanks, Bill
pciaccio Sun, 10/14/2007 - 06:06
If you are using Cisco VPN client software and you connect to the VPN server (PIX/ASA/VPN Conct)It is the function of the VPN server that dictates the tunnel time. You need to talk to your VPN administrator and tell them your concerns. The time can be increased but the server pushes its parameters out to you upon your authenticated log in....
