PE - PE Links ( Best Practise ???? )
Oct 14th, 2007
ALL ,
As per recommended best practise , would it be advisable to have PE to PE connectivity ( both IGP & ldp connectivity ) for resiliency.
Scenario is you have collocated PEs running VRRP with dual homed CEs??
Any comment or Suggestion ?
swaroop.potdar Sun, 10/14/2007 - 14:40
  • Blue, 1500 points or more
Can you please elaborate the question further.
HTH-Cheers,
Swaroop
g.oridota Sun, 10/14/2007 - 23:46
Hi Swaroop,
I have two PE routers in the same sites with uplinks to different P Nodes. The PE Nodes run vrrp on the LAN interface for the various LAN Based CE devices.
However , if one P-PE links fails , traffic is not routed via the second PE .
Is it advisable to run direct links between both PEs and turn on label switching as per recommended best practise ??
swaroop.potdar Mon, 10/15/2007 - 05:37
Hi G,
Do refer to this link if you topology is similar to the topology shown in this document for HSRP support for MPLS VPN;s then it will work.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00806993c5.html
As although this support for VRRP is not mentioned, but when i tested it it worked fine with VRRP as well, populating the right arp and cef entries for the VRF beneath.
HTH-Cheers,
Swaroop
