PIX515 - Reset to factory default in monitor mode
Oct 14th, 2007
Hi all,
All is in the title !
Is there a way to reset a PIX515 to default configuration FROM MONITOR MODE.
Why in monitor mode ?
In fact I have sent a configuration using tftp into startup and reloaded the PIX. After this, the PIX boot normally until the loading of the configuration : At this point, there is a traceback and a dump of memory...
So I'm looking for a way to reset the configuration to default but I have only access using monitor mode.
JORGE RODRIGUEZ Sun, 10/14/2007 - 15:46
Ludovic, it is not possible to reset pix config to factory defualts in monitor mode as there is not code loaded in this mode, can you load a new code? if pix is crashing it is possible code is corrupted.. the only way to reset config to factory defaults is through pix configuration mode.
ldesmasures Sun, 10/14/2007 - 22:45
Thanks for your answer.
The problem is not the code (actually 7.0(5)) because I have tried to boot on another code (8.0(2)) and the result is the same...
Thanks a lot, the only thing I can do now is a RMA !
