10-14-2007 12:04 PM - edited 03-03-2019 07:09 PM
I have a 806 running c806-o3sy6-mz.122-4.YH.bin. I need to know what version of IOS image do I need to be able to default router to DHCP (IP ROUTE 0.0.0.0 0.0.0.0 DHCP). I cannot do this with what I have. THanks in advance.
10-14-2007 01:02 PM
You might be using an incorrect approach.
What you want to achieve can be configured like this:
ip dhcp pool IAS
import all
origin ipcp
interface Ethernet0
description Connection to Customer network
ip address pool IAS
interface Dialer0
ip unnumbered Ethernet0
This is taken from the working config of an ADSL router. In this config, the default route is "imported" via the IAS pool. The same might be applicable to your 806.
regards,
Leo
10-14-2007 01:53 PM
There is no need for a dialer interface because it is not PPPOE or PPPOA. This is just a stright up Bridge im connecting to and it assigns whatever interface is connected to it a dynamic IP address.
10-14-2007 04:15 PM
Pearcy, as per command reference, the feature has been introduced in 12.3(8)T.
