Multiple servers under one DMZ
Oct 14th, 2007
Hi all!
is it possible for ASA or PIX firewall to handle multiple servers under its DMZ interface? Example, we have only one outside ip address and we have 6 servers inside the DMZ. is it possible to access every server coming from outside using this one outside ip address? we have one email server, 2 web server and the rest are some other servers. is this posible? if yes, can you give me a link or tutorial on how can i configure the firewall so that it can handle this instances.
kevin.jones1 Sun, 10/14/2007 - 19:17
Yes, it is possible. You just have
place those servers behind an F5 BigIP
that will do the load balancing for you.
on the ASA, you do a port-redirect
static(dmz,outside) tcp interface 80 x.x.x.x 80 netmask
where x.x.x.x is the ip address of the BigIP
Virtual IP (VIP).
