Configure 2 mc3810's to double the available analog ports.
Oct 14th, 2007
I presently have an mc3810 with 6 e&m ports connected via t1 voatm over a microwave link to a distant mc3810 with 6 e&m ports. Is it possible to add a mc3810 at each end connected by their ethernet ports with a x-over cable to double the number of e&m ports available without using another t1? Thanks
Dennis Fogler Mon, 10/15/2007 - 02:30
  • Cisco Employee,
This will work as long as its an MC3810 "V3" the "V3" unit supported H.323 dial-peers, which you will use to route calls on the second 3810, you add, to the 3810 with the t1 voatm connection. Basically voip between the two units with a cross over cable.
