Display Name on CME
Oct 14th, 2007
We are using CME. The problem is the phone is not showing the name of the user on the phone. It just shows the main number and extension. I have checked the config and it looks fine on CME.
Tks
Dennis Fogler Mon, 10/15/2007 - 04:46
Are these calls ip phone to ip phone calls or are they external to ip phone calls?
Also make sure you have the "name" field defined under "ephone-dn" command.
