1242 and 5.8G solid dish 3 miles?
Oct 14th, 2007
All,
I'm in Iraq and I was using the "B" side on at 3 miles away with a solid dish "AIR-ANT3338" and was getting 2meg down on by bandwidth and now I'm lucky to get 400K. I have one root hub and 4 non root hubs linking to it with no more than 6 users at each shot. I've replaced the Root hub checked the cable and so on. The Army Camp has grown like you wouldn't believe with everyone using 2.4G so I want to move to "A" side 5G. Do you know if the "AIR-ANT58G28SDA-N will work with the 1242 and if not what is everyone else using? It's hard to find information when you're in Iraq and I never know where my equipment is purchased from.
Many Thanks
DK
ericgarnel Tue, 10/16/2007 - 05:01
  • Gold, 750 points or more
The 1242 has rp-tnc connectors while the AIR-ANT58G28SDA-N has an N connector. you will need to get a converter to go from N to rp-tnc. Without seeing the antenna, I would guess that you would need a converter with a male "N" and a female "rp-tnc". There will be some minor loss with the adapter. The AIR-ANT58G28SDA-N is designed for the 1400 series, but contact TAC and ask for sure if it will work with the 1242 series.
dennischolmes Wed, 10/17/2007 - 11:17
This config would work but why do you suspect you had such a radical drop in bandwidth. My suspicion is either interference or polarity.
D
sorvarit Wed, 10/17/2007 - 13:47
Your dish antenna is a 21dBi model and like another has suggested its more likely you have some sort of interference. Tried another channel? We run a 2,4GHz link with a 10dBi omni on the root (Aironet 1231G) and gets 36Mbps link with a 18dBi dish 5Km away on the client side (Aironet BR1310).
Are the cable runs to the antennas long? Check this out:
http://www.radio-electronics.com/info/antennas/coax/coax-environmental.php
