MGCP incoming call number manipulation
Answered Question
Oct 14th, 2007
Hi All,
Does anybody know how to do MGCP incoming call number manipulation? for example, the incoming call number is 8971001, I need the call routed to extention 1001.
Because MGCP don't have the option to select the significant digit (e.g. 4 digits) in callmanager, how can I do this?
Thank you!
Best Regards,
Teru Lei
Correct Answer by nomiel about 9 years 4 months ago
Hi.
You can configure Translation pattern. If you use Calling search space in mgcp-gateway configuration, then this translation pattern must be in partition, that is accessible to this gateway.
In translation pattern configuration page enter:
Translation Pattern - 897XXXX
Called Party Transform Mask - XXXX
Overall Rating: 5 (1 ratings)
Correct Answer
nomiel Mon, 10/15/2007 - 01:41
Hi.
teru-lei Mon, 10/15/2007 - 23:34
Thanks nomiel. But besides that, no other ways for MGCP? because for H323 gateway and trunk, there is incoming and outgoing digital manipulation, but just for MGCP, I can not find...
nomiel Mon, 10/15/2007 - 23:45
As I know, there is only way to manipulate digits with mgcp is to use translation patterns. It's not so difficult and you can change manipulation rules without gateway reset.
