cannot collect configuration from MDS 9216i
Oct 15th, 2007
I am using LMS 2.6 with RME 4.0.5.
What solve this problem?
aghaznavi Fri, 10/19/2007 - 09:32
May be some issues between your fabric switch and RME because MDS 9216 required minimum version is 1.0.1 so make sure of your version.
palexandr Sun, 10/21/2007 - 18:58
Version above 1.0.1
BIOS: version 1.1.0
loader: version 1.2(2)
kickstart: version 3.0(2a)
system: version 3.0(2a)
Description of the error message
CM0056 Config fetch failed for 10.x.x.x Cause: CM0204 Could not create DeviceContext for 46 Cause: CM0206 Could not get the config transport implementation for 10.x.x.x Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Required device package ?
