CCNP to CCIP
Oct 15th, 2007
If I have an active CCNP and would like to complete CCIP, do I still need to take "642-901 OR 642-892"?
I was thinking that since I have an active CCNP, I just need to take "642-642, 642-661, and 642-611" OR "642-642 and 642-691" although I got my CCNP not taking either "642-901 OR 642-892" - old CCNP.
Dandy
rainer_rudigier Mon, 10/15/2007 - 05:14
hi Dandy,
you can check at
http://www.cisco.com/go/certifications/login/
(login with your CSCO... id)
under "certification progress" you get the info
under CCIP it states for BSCI/COMPOSITE -- complete one from 642-801, 642-901, 642-891, 642-892
so you should be fine with 642-801 or 642-891 from your CCNP
QOS, BGP and MPLS and you are a CCIP :-)
hope that helps
rainer
Danilo Dy Mon, 10/15/2007 - 05:49
Thanks for your reply. My CCNP is way older than that, I know that each 642 exam is valid for 3 years. I was just thinking that for active CCNP going to CCIP there's no need to take the BSCI/COMPOSITE :) it will save us $$$ and time since as an active CCNP we should know that stuff, they may as well tell CCIE's to take the LAB for recert not the Written :)
Dandy
