ankbhasi Mon, 10/15/2007 - 02:11
Hi Sanjoy,
Can you update exactly which switch mode do you have or can you paste the "sh version"?
If you already have 2950 EI switch then it should support QOS commands?
Ankur
sanjoy2006 Mon, 10/15/2007 - 02:32
sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 08-May-07 11:50 by myl
Image text-base: 0x80010000, data-base: 0x8056C000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 14 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA10.bin"
cisco WS-C2950-24 (RC32300) processor (revision B0) with 20970K bytes of memory.
Processor board ID FOC0533X1AM
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:50:16:15:00
Motherboard assembly number: 73-5781-13
Power supply part number: 34-0965-01
Motherboard serial number: FOC053300UU
Power supply serial number: PHI052902MP
Model revision number: B0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FOC0533X1AM
Configuration register is 0xF
Switch#
MUHAMMAD SHAHEEN Mon, 10/15/2007 - 05:34
This switch WS-C2950-24 can only run SMI and not capable to run EMI.
Cisco IOS is very intelligent, even if you install EMI onto a WS-C2950-24 switch, it will only install SMI code.
HTH,
Shaheen
ankbhasi Mon, 10/15/2007 - 05:51
Hi Sanjoy,
2950 model switch which you have will only run standard image and cannot be upgraded to enhanced image but this does not mean it will not support QOS. It will suppor tbut yes not all advance features.
You can have a look at this link which will tell you what all qos features can this switch support running SI image.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/configuration/guide/swqos.html#wp1072297
http://www.cisco.com/en/US/tech/tk389/tk813/technologies_q_and_a_item09186a00804976d3.shtml#qa1
Ankur
*Pls rate all helpfull post
