Netflow config on a 6500
Answered Question
Oct 15th, 2007
Hey guys,
I read through the documentation and saw that to configure netflow for the PFC, you use the mls nde commands. Thats all straighforward.
What I dont get is for the netflow on the RP, they tell you to use "ip route-cache flow" command.
What I couldn't find anywhere was, does this impact CEF switching at all? Does this conflict with "ip route-cache cef"? Before I issue this command, I want to make sure that this command does not impact the performance and also does not disable cef for the interface its applied to.
Thanks for any and all clarifications.
Edit: On a shutdown interface, I see these changes when I apply "ip route-cache flow"
Before:
#show cef interface t1/1
TenGigabitEthernet1/1 is down (if_number 4)
IP CEF switching enabled
IP Feature Fast switching turbo vector
IP Feature CEF switching turbo vector
After:
IP Flow switching turbo vector
IP Flow CEF switching turbo vector
Correct Answer by Jan Nejman about 9 years 8 months ago
don't worry, if you select "ip route-cache flow" your CEF configuration remain unchanged. You can use "ip flow ingress" instead of route-cache command.
"ip flow ingress" is supported in release 12.2(18)SXD and later releases.
"ip route-cache flow" is deprecated in release 12.2(18)SXD.
Best regards
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Overall Rating: 4 (1 ratings)
Correct Answer
Jan Nejman Mon, 10/15/2007 - 23:52
  • Bronze, 100 points or more
Best regards
Jan Nejman
Caligare, Co.
