DST question
Oct 15th, 2007
How do I verify what the current dvice pack level(for instance somebody applied device pack 36 back in April 1) and whether the ciscocm.4-1-3-2007-DST-Update.1-0-1 has been applied?
Rob Huffman Mon, 10/15/2007 - 09:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi CF,
Check Device Defaults Page to see if the 7906, 7911, 7941, 7961, 7970, 7971 are running at least 8.2.2sr1;
To check for the DST Patch one way would be to look for this; Start/Settings/Control Panel/Add/Remove Programs/Cisco Unified CallManager ciscocm.4-1-3-2007-DST-Update.1-0-1.exe Uninstall
Daylight Saving Time Solution Overview
Depending on the configuration, there are up to four software items which may be required to make a CallManager system Daylight Saving Time compliant.
CallManager Database Table update - ciscocm.4-1-3-2007-DST-Update.1-0-1.exe
Phone Loads - 8.2.2sr1 standalone phone load
***IMPORTANT NOTE***:
For 7906, 7911, 7941, 7961, 7970, 7971, in addition to the above phone loads, there is one manual workaround that will be needed in order to get the phones to display the correct time:
Reset the IP phone from the CCMAdmin for the phone to get the correct time.
Please be aware, that if for some reason, the phone is power cycled, the phones need to be reset from the CCMAdmin again for the phone to get the correct time.
JRE Patch - JRE Patch: (ciscocm-2007-JRE-DST-Update.1-0-1.exe)
This patch is only applicable to 3.3(5), 4.0(2a), 4.1(x), and 4.2(x). This patch enables CAR and AST to use the new Daylight Saving Time Zone.
Windows 2000 Patch - The Windows 2000 Daylight Saving Time patch is installed if any of these versions of MCS OSs are installed. All nodes are required to be on the same version. This patch affects CallManager tracefiles timestamps and the time display on the server's console.
2000.4.4a(sr3a) or higher
Shown nicely in this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a00807e02b1.shtml
Hope this helps!
Rob
eduestme2 Wed, 10/17/2007 - 09:47
Rob,
Who uses 4.2.3 versions need make this?
Problem with the ip communicator and ip phones. We are utilizing the version Ip communicator 2.0.21 and callmanager 4.2.3, but do not we obtain to bring up to date for the schedule of summer, therefore stayed always with a hour of delay in the clock, even though the computers be with the correct schedule and the callmanager server. When I select "Automatically adjust clock daylight saving changes" does not work in the ip communicator and ip phones.
