Destination ip translation on Pix version 6.2.
Oct 15th, 2007
Traffic is fron Inside to Outside. When users from Inside connect to a host on the Outside with destination IP of, the pix should translated to The documentation said you can use static for Lower to Higher security. This scenario is however from Higher to Lower. Can I still use static or do I have to use Nat? Please post the command for either method. Thank you.
acomiskey Mon, 10/15/2007 - 06:14
static (outside,inside) netmask
