2960 Switch layer3
Answered Question
Oct 15th, 2007
Can anyone confirm whether the 2960 has layer 3 routing capability? I'm considering these instead of 2950 as they seems to be end of life now,
Correct Answer by ankbhasi about 9 years 6 months ago
Hi Friend,
3560 switch will work as DHCP server same as 3550 so you need to worry about the same. It will work fine as per your requirement.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
ankbhasi Mon, 10/15/2007 - 07:01
  • Cisco Employee,
Hi Friend,
Cisco layer 3 switch category starts from 3550 models. 2960 is a pure layer 2 switch.
You can go for 3560 instead which will give you layer 3 capability.
Ankur
rasoftware Mon, 10/15/2007 - 07:06
Hi thanks. What I want is a 3560 as layer 3 and about 8 x 2960 as layer 2s. I assume base LAN OS for the 2960 and SMI for the layer 3 will allow me to have vlan database across all switches (as with 2950/3550) and use the layer 3 (3560) as gateway/dhcp?
can you also confirm 3560 has dhcp server still - same as 3550?
ankbhasi Mon, 10/15/2007 - 07:10
  • Cisco Employee,
Hi Friend,
Yes if this is just your requirement SMI image will work on 3560 but if you are looking for some advance routing protocols like ospf, egrp and bgp and some other davance functionality like QOS you have to get EMI image.
But if your requirement is to have routing between vlans and switch working as DHCP server it will work fine and you can also have static routes and default routes configured on this switch with ski image with basic routing protocol like RIP.
Ankur
rasoftware Mon, 10/15/2007 - 07:14
Yes basically I have a office which has a 3560 plugged ito my shared firewall. I define VLAns on here which I want available on each of the 2960. I also provide DHCP from the 3560. Thats all the functionality I need. Each client on the various VLANS gets a gateway in the 3560 via dhcp and the local client plug into their VLAN on each switch. 3560 handles the routing and out to the firewall. Is essentially a shared internet service. Just wanted to check nothing had changed with the later switches.
Correct Answer
ankbhasi Mon, 10/15/2007 - 07:20
  • Cisco Employee,
Hi Friend,
Ankur
