ASA 5505 to Watchguard x1000
Oct 15th, 2007
Trying to get a VPN tunnel up from an ASA 5505 to a Watchguard X1000 firewall at our colo. I'm a total newb at Cisco VPN configs, so I've probably got something monkeyed up...
By the debugs, it looks like Phase 1 and Phase 2 both are coming up, but the tunnel gets closed out immediately. 1.2.3.4 is the ASA 5505, 5.6.7.8 is the X1000:
9:43 AM IP = 5.6.7.8, IKE Initiator: New Phase 1, Intf 0, IKE Peer 5.6.7.8 local Proxy Address 10.20.2.0, remote Proxy Address 10.1.0.0, Crypto map (mdc-vpn-map)
9:43 AM Group = 5.6.7.8, IP = 5.6.7.8, Freeing previously allocated memory for authorization-dn-attributes
9:43 AM AAA retrieved default group policy (DfltGrpPolicy) for user = 5.6.7.8
9:43 AM Group = 5.6.7.8, IP = 5.6.7.8, PHASE 1 COMPLETED
9:43 AM Group = 5.6.7.8, IP = 5.6.7.8, Security negotiation complete for LAN-to-LAN Group (5.6.7.8) Initiator, Inbound SPI = 0x6c81df4e, Outbound SPI = 0x68bee110
9:43 AM IPSEC: An outbound LAN-to-LAN SA (SPI= 0x68BEE110) between 1.2.3.4 and 5.6.7.8 (user= 5.6.7.8) has been created.
9:43 AM IPSEC: An inbound LAN-to-LAN SA (SPI= 0x6C81DF4E) between 1.2.3.4 and 5.6.7.8 (user= 5.6.7.8) has been created.
9:43 AM Group = 5.6.7.8, IP = 5.6.7.8, PHASE 2 COMPLETED (msgid=6b391f01)
9:43 AM Group = 5.6.7.8, IP = 5.6.7.8, Connection terminated for peer 5.6.7.8. Reason: Peer Terminate Remote Proxy 10.1.0.0, Local Proxy 10.20.2.0
9:43 AM IPSEC: An inbound LAN-to-LAN SA (SPI= 0x6C81DF4E) between 1.2.3.4 and 5.6.7.8 (user= 5.6.7.8) has been deleted.
9:43 AM IPSEC: An outbound LAN-to-LAN SA (SPI= 0x68BEE110) between 1.2.3.4 and 5.6.7.8 (user= 5.6.7.8) has been deleted.
9:43 AM Group = 5.6.7.8, Username = 5.6.7.8, IP = 5.6.7.8, Session disconnected. Session Type: IPSecLAN2LAN, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: User Requested
9:43 AM User 'username' executed the 'ping inside 10.1.0.2' command.
Any clues? Debug text and the config file are attached...
ASA 5505, ASA v7.2(1)
Watchguard Firebox X1000, Fireware v9.1
rmeans Mon, 10/15/2007 - 09:23
This would suggest that your rules for encryption do not match or has a problem (acl mgc). We need to sure you side matches the inverse of the Watchguard. Of course you need to make sure you are sending the data to Watchdog as a private 10.20.2.0/24 address. This led me to look at your NAT rules. I noticed that all internal addresses PAT to the outside interface address. I think you should add a nonat rule for the VPN traffic. Something like
access-list nonat permit ip 10.20.2.0 255.255.255.0 10.1.0.0 255.255.255.0
nat (inside) 0 access-list nonat
This will prevent the inside addresses from NAT when going across the VPN to Watchguard. I would not reuse the mgc acl. Defining a separate acl gives you flexibility in the future.
If you still are having trouble check the Watchguard rules for encryption.
