CCMv4.2.(3)sr1 & Veritas
Oct 15th, 2007
I'd like to install the Veritas agent on the CCM appliance. I found the responses on the topic but the links are all broken. They were all pretty old posts - 1/2006. Is there any new info out there? Does anyone have the correct links for guidelines when it comes to installing back up software?
Thanks, Kim
astrohmeier Thu, 10/18/2007 - 06:52
its not allowed to install Veritas. The only backup tool you can use is bars. If you install Veritas you mill lose your support from Cisco.
kind regards Achim
kimlong Fri, 10/19/2007 - 05:03
We are required to keep the accounting information that is logged by CM for a number of years. The BARS doc says to refer to the "Cisco MLA documentation". I didn't find anything in the CUCM Security Guide or System Guide on this. And I didn't find a specific MLA doc. Pointers to more information would be appreciated.
