10-15-2007 09:33 AM - edited 03-10-2019 03:49 AM
Device Status > Connection Status:
"Status unknown. IEV server program may not be running."
And I get this error when I click 'update' in device properties:
"IOCException: Connection refused: connect
IEV server is not responding. Please check if it is running."
I attached a pic of the console window.
What's most likely my problem/error here?
10-15-2007 02:10 PM
You have likely crashed the "Anaylis Engine" process. To verify this is the problem, try logging into the sensor in the CLI. When you have logged in, do a "sho ver". Make sure all of the services are running. If one or several are stopped, you will need to restart. You can do this by 1) rebooting manually or 2) rebooting via CLI with the reset command.
Jay
10-15-2007 02:13 PM
I'll try it. Thanks.
