ip as-path
Oct 15th, 2007
I was looking over a router config when I ran across the following:
ip as-path access-list 17 permit ^[0-9]+$
ip as-path access-list 17 permit ^$
what is the meaning of this I tried looking it up but maybe I'm not understanding what I read....sorry for the silly question
Thank you warren
Overall Rating: 5 (3 ratings)
cisconoobie Mon, 10/15/2007 - 10:54
(ip as-path access-list 17 permit ^$) is used for bgp updates sent to peers.
There should be a router bgp route-map associated with this.
Means all networks originating from your AS and no others, protects your AS from becomming a transit-as.
The other command, I'm not exactly sure, have to do the math.
Haris P Mon, 10/15/2007 - 11:23
  • Bronze, 100 points or more
the statement ^[0-9]+$ will match bgp routes originated from next upstream ....that's with AS-path length 1 , the next statement ^$ is will match the routes originated by the router... So The as-path 17 will be a summary of routes originated from next upstream and routes originated by the router
Haris
wgranada1 Tue, 10/16/2007 - 08:38
Thank you all for the info it was very helpfull and thank you Haris for the explaination!!!
