IP Phone SDK LDAP Search Help Needed
Oct 15th, 2007
We are using the LDAP Search for our Global Directoy so that we can display the phone number from AD's IP Phone field. We would like to not include accounts that have the msExchHideFromAddressLists flag set to hidden.
Does anyone know the syntax to the ldapdirectorylist.asp script?
Can it be done by using a s.AddReturnAttr statement?
Mike
lburleso Tue, 10/16/2007 - 14:01
Could you furnish the LDAP query string that you are using?
If you are using the SQL syntax, you will need a parameter that looks something like:
WHERE msExchHideFromAddressLists=1
among others.
