Suitable IOS
Oct 15th, 2007
I need your support to identify a correct IOS for my routers to enable SP Services. Please see the attachments to see the show version of my present routers.
Will the IOS for 2621XM and 2610XM be suitable for the cisco 2610 (MPC860) and cisco 2621 (MPC860) series router.
Request your valuable suggestions on this.
K.V.Krisshna
JORGE RODRIGUEZ Mon, 10/15/2007 - 14:22
  • Green, 3000 points or more
go to this link
www.cisco.com/go/fn
1- search by image
2- Software (select IOS )
3- Platform ( Select your router type)
Then continue to next screen
1- Select Major Release IOS version
2- Release ( Select ALL releases )
3- Select feature set ( SP services )
it will post IOS version, RAM and FLASH required for SP services on your platforms.
Jorge
