Conflicting Device Types
Oct 15th, 2007
How do I check the following ID's to select the correct type for resolution?
If I check the box and click update, it resolves the issue. I just want know if the RME is recognizing the correct info.
172.16.x.x
SysObjectID in DCR 1.3.6.1.4.1.9.1.201
SysObjectID found by RME 1.3.6.1.4.1.9.1.620
Thanks in advance.
Overall Rating: 5 (2 ratings)
jreekers Tue, 10/23/2007 - 18:15
  • Cisco Employee,
Hi.
The best way to determine what a specific sysObjectID refers to is to bounce it against the CISCO-PRODUCTS-MIB.my which you can see here:
ftp://ftp-sj.cisco.com/pub/mibs/v2/CISCO-PRODUCTS-MIB.my
so for 1.3.6.1.4.1.9.1.201 (which is ciscoProducts.201) we see:
cisco1720 OBJECT IDENTIFIER ::= {ciscoProducts 201 }
and for 1.3.6.1.4.1.9.1.620 (which is ciscoProducts.620) we see:
cisco1841 OBJECT IDENTIFIER ::= { ciscoProducts 620 } -- 1700 Next Generation data only router with 2 slots
HTH,
-Joe
jreekers Tue, 10/23/2007 - 18:16
  • Cisco Employee,
Hi.
HTH,
-Joe
  • Cisco Employee,
Hi.
HTH,
-Joe
  • Cisco Employee,
wow...sorry for the duplicate posts... :-)
