10-15-2007 01:58 PM - edited 07-03-2021 02:46 PM
I am trying to enable SSID broadcasting on my 871W, but have had no luck, and am unable to find anywhere online that describes the process. It is disabled by default, so is it possible to re-enable? Thanks for any help!
10-15-2007 02:18 PM
Hi Derek,
The command that controls the "Broadcast" of the SSID is "guest mode". Have a look;
guest-mode (SSID configuration mode)
Use the guest-mode SSID configuration mode command to configure the radio interface (for the specified SSID) to support guest mode. Use the no form of the command to disable the guest mode.
[no] guest-mode
The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with the access point. It also allows clients configured without a SSID to associate.
Examples
This example shows how to set the wireless LAN for the specified SSID into guest mode:
(config-if-ssid)# guest-mode
This example shows how to reset the guest-mode parameter to default values (no broadcast SSID):
(config-if-ssid)# no guest-mode
From this IOS Command doc;
Hope this helps!
Rob
10-15-2007 02:24 PM
Looks like what I am looking for!
Thanks Rob!
