Maximum PoE 802.3af distance 15.4W
Answered Question
Oct 15th, 2007
I've got a new wiring project coming up shortly that may tax the limits of cat5e standards.
I am having trouble locating documentation that says what a theoretical maximum distance for a 802.3af class 3 device will be.
Has anyone run into problems with voltage loss over long distances? Will I be OK as long as the wire passes a fluke cat5e test?
Correct Answer by Rob Huffman about 9 years 8 months ago
Hi JP,
The standard 100m ethernet rules (90m drop + 10m patch/cross connect) still apply here. If the cables fall within this standard and pass the testing with good results you should be good to go.
Hope this helps!
Rob
Overall Rating: 3 (1 ratings)
Correct Answer
Rob Huffman Mon, 10/15/2007 - 15:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi JP,
Hope this helps!
Rob
