What the heck does "fabric enabled" really mean??
Oct 15th, 2007
I have searched Cisco's website high and low for a GOOD explanation of what exactly fabric enabled means but I cant find it.
Anyone have anything to offer in this regard?
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 10/15/2007 - 16:01
Fabric Enabled means the module has an additional connection directly onto the switch fabric.
For instance, this is a 6748 card - fabric enabled. You see both connectors in the back ? The rightmost interface connects to the Bus and the leftmost interface connect to the fabric.
http://i20.tinypic.com/2lnbb5u.jpg
I also suggest you read this link:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper0900aecd80673385.shtml
lamav Mon, 10/15/2007 - 16:34
Eison:
Thanks, buddy. Im getting a better picture.
I am trying to recommend a robust LAN campus/user-access switch for mission critical Tier 1 sites for a financial comp.
I am thinking that the 6509 with dual SUP32-PISA is a great choice. Its not fabric enabled, though. It just uses the classic 32Gbps bus.
For the Server farm access, i was going to recommend a 6509 with dual SUP 720s and 10 Gig uplink capability.
What do you think about both recommendations?
Thank you once again
Edison Ortiz Mon, 10/15/2007 - 16:40
Are you planning to use the PISA for user access ? If so, I recommend looking at the 4500 line for that task.
PISA is great for distribution switch, great NBAR hardware support and SUP720 is great at the Core and/or server farm.
lamav Mon, 10/15/2007 - 16:48
You know, my initial thought was to recommend the 4507R with dual sup V, but I had second thoughts after I cosidered the idea that it is getting to be an old platform.
The client is lookign for a next generation switch to support a "world class data center." I cant help but think that the 6500 may be the better platform....I am not sure.
lamav Mon, 10/15/2007 - 16:58
Let me reiterate....these switches would be for the LAN/user access..
For Server access (servar farm) I would definitely use fabric enabled dual SUP 720s
