Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1930151members
1245729discussions
Community Activity
[Intersight]Cisco.com IDを利用した多要素認証(MFA)の設定方法
はじめに注意事項事前準備設定の流れ設定例参考情報   はじめに  Intersight SaaSでMFA(Multi Factor Authentication )を設定する手順をご紹介します。  Intersightでは Cisco.com IDでの認証とDuo または Google Autenticatorを組み合わせた多要素認証(MFA)を使うことができます。本資料では上記のMFAを行うための手順についてご紹介します。 注意事項 MFAは1つのintersight Saasアカウントに...
tjimbo by Cisco Employee
  • 0 Views
  • 0 replies
Web Application Server
Dear Community,I'm asking for you guidance. I have come across a challenge on Cisco ASA version 9.8. Need to allow a web server to be access outside(Public) from DMZ Zone to Ouside Zone.  Per below configuration template. Nat is transilating but acce...
dissai by Level 1
  • 288 Views
  • 13 replies
IP connectivity between Nexus and Palo Alto firewall
I'm struggling to understand connectivity problem between a switch and firewall.  The Nexus is located between the Core switch and the edge firewall. It's purpose is to divert traffic via ITD for content filtering.  My problem right now is that I'm n...
jeff20 by Level 1
  • 355 Views
  • 25 replies
Spoke stuck on IKE state in DMVPN
Hi,We have mGRE DMVPN tunnle between one Hub and 7 Spokes. Other 6 Spokes are working fine but one Spoke is not connecting to Hub.Spoke shows DMVPN on IKE state (tunnle is not working) and Hub is not adding nhrp entry in table.Spoke DMVPN TunnelPleas...
INBKIT_0-1713981579965.png INBKIT_3-1713982713738.png INBKIT_4-1713982931986.png INBKIT_5-1713983001947.png
INBK-IT by Level 1
  • 241 Views
  • 11 replies
S2S VPN Cisco FTD (Managed by FMC) <=> Fortigate
Hi AllI have a S2S VPN connected at phase 1, however doesn't successfully negotiate Phase 2. The issue I have is that my Cisco FTD sits behind a NAT device. I have configured NAT-T.My configuration on my FTD has the local peer configured with the pri...
C-921 Cisco router intermittent internet cut off after some days
I have an intermittent internet cut off after around some days of working (5 to 10 days). The router becomes inaccessible by ssh. No ping also from internet and from inside. The architecture includes two switches (CBS350-48FP-4X) with Vlan1.We did no...
dhaferbk by Level 1
  • 11 Views
  • 0 replies
Updated to Ubuntu 24.04. I am not able to use Secure-VPN anymore
Hi, as the title says, I am unable to connect to my Cisco Secure VPN after updating my OS from Ubuntu 22.02 to 24.04. The error I receive is"You are missing the required libraries for the authentication method you requested."Upon closer inspection, t...
rorororo by Level 1
  • 36 Views
  • 0 replies
notconnect vs notconnect:
Recently I've seen some switches show ports with a status of "notconnect:"  What does the colon at the end signify?I don't have it documented where all I've seen it but I just now saw it on a 6 stack of WS-C3650-48PD running 16.12.06. About 85% of ou...
stonent01 by Level 1
  • 599 Views
  • 6 replies
NTP Setup, but I got .INIT. state..
Hello Professionals,I setup the NTP server in one of branch site and would like to make all network switches to see this server including other branches. - NTP server: 10.10.10.158 (placed in CST timezone, it refers pool.ntp.org) - NTP Client: Switch...
eeebbunee by Level 1
  • 81 Views
  • 3 replies
Webex calling routing
Hi guys we had an issue routing to webex calling to our on prem cucm via the trunk.we could not dial webex users from our cucm via the trunk, but we could dial the same numbers from webex to cucm.i added a route to the source number from webex to poi...
Max number of licenses available for Cisco ISE
I'm speaking of Essentials/Advantage/Premier. We use on-prem SSM.is there way to know how many licenses Cisco ISE gets from the binding to a virtual account on Cisco SSM?The only piece of information is the consumed ones, like knowing how many you ar...
ikev2 VPN tunnel trouble shooting help
Howdy Cisco Community!Need your help as fairly new trouble shooting site to site VPN connectivity.I am unable to establish VPN connectivity per information below.Site:1crypto ipsec ikev2 ipsec-proposal CSM_IP_1protocol esp encryption aes-256protocol ...
Makoon by Level 1
  • 208 Views
  • 10 replies
Resolved! UCCE: How to find dialed number using SQL query
Gents, Which table does the dialed number gets stored in. I need to know how to find the dialled number rather than manually going through each dialed number list as this can be very time consuming as you can imagine. Thanks
Cisco Catalyst 9500 - IOS Upgrade
Hello together, I want to upgrade to a Cisco Catalyst 9500. I enter the following command:install add file bootflash:cat9k_iosxe.16.09.04.SPA.bin activate commit The following line I confirm with Yes:Please confirm you have changed boot config to boo...
