Can WIC and HWIC coexist?
Oct 16th, 2007
I have a 2811 with c2800-advsecurityk9-m, version 12.4 (11)xw, which i recently installed.
up to recently, i only had a single wic (adsl over pots) installed that i used for my internet.
i decided to add a second line to our office, and so ordered an hwic (adsl over pots). however, the router see's only one of them at a time, whichever one is installed in 0/0.
Any ideas?
Paolo Bevilacqua Tue, 10/16/2007 - 02:07
which exact version of 12.4(11)XW ? can you upgrade to XW4 and try again?
Also please collect output of show ver and show diag, post it here.
Paolo Bevilacqua Tue, 10/16/2007 - 04:37
You should upgrade anyway because very first XW has many bugs and has been deferred.
I can't tell if it will work. The wic card is not recognized when coexisting with hwic. If after upgrade problem still exist, I suggest that you contact the TAC for assistance.
Paolo Bevilacqua Wed, 10/17/2007 - 05:26
You may be running into some sort of incompatibility, no matter the IOS used, and the last word on that is to cisco.
I think two HWICs should work.
Paolo Bevilacqua Thu, 10/18/2007 - 02:17
You definitely need to confirm with cisco on this issue. If the producet are still new you are entitled to support even in lack of a contract, mention this to the dispatcher and they should open a case for you.
