suggest model
Oct 16th, 2007
Kindly Suggest model for below mentioned product.
Technical Specification 24 Port Switches
Physical Interfaces
? 24 ports Fast Ethernet RJ45 Full Duplex with optional PoE support and optional K.21
Protection with Two SX GBIC Multi Mode Module fitted.
? 2 SFP Gigabit Ethernet Optical ports
? 2 ports 10/100/1000 Ethernet RJ45 Full Duplex
Power Supply
? Fixed PSU
? -48V DC / Universal AC Input (110-230V,
50-60Hz)
Dimensions
1U 19? Rack Mountable
VLANs
? IEEE802.1q, 4096 VLANs supported
? GARP, GVRP support
? IEEE802.1v Port/Protocol Based VLAN
support
Quality of Service
? QoS at VLAN level
? IEEE802.1p Class of Service
Power Over Ethernet (PoE) (Optional)
? -48V DC up to 15.6W on each port
? In DC Power Supply model only
Security
? Port Isolation (Protected Port Support)
? IEEE 802.1x Port based Authentication
? RADIUS Client Support
? DHCP Relay and DHCP Option 82
Management
? Telnet, SSHv2
? Industry Standard CLI (with multiple user access)
? Port mirroring for debugging & monitoring
2.
Technical specification Distribution Switches
1 Rack unit with 12 SFP ports and throughput up to 1Gbps fitted with one LX/LH Transceiver Single Mode Module and six SX Transceiver Multi Mode Modules.
QOS, IP Base Service Image IOS, Routing at access Layer.
Adaptive Real-Time RF management.
Layer 2 and layer 3 securities with multiple Extensible Authentication Protocol.
VLan and Support up to configuration of 1005 VLans.
Policy Control with Admission Control.
Managed through Command Line Interface as well as Graphical User Interface.
Spanning-Tree Configuration with Redundancy for Fault Backup.
TACACS + and Radius Authentication.
Port Security, Bandwidth Management, IGMP Filtering.
802.1Q Tagging, VTP for Dynamic Trunk Configuration.
Remote Switch Port Analyzer (RSPAN)
Compatible with SNMS Software?s.
Configurable up to 12,000 MAC addresses.
Configurable up to 20,000 unicast routes.
Power supply supports input voltages between 100 and 240VAC.
Per-port status LEDs: link integrity, disabled, activity, speed, and full-duplex indications.
System-status LEDs: system, RPS, and bandwidth-utilization indications.
TFTPv2 for software updates
SNMP v1/v2/v3
Telnet, SSHv2
Dual Application Image support
Dual Configuration support
Trusted Manager List
