Vpnclient 5.0.01.0600
wdbrewster
I upgraded my vpnclient from 4.6.04.004 to 5.0.01.0600 and now traffic is not passing between the ASA5510 and the PC. The same is happening between the PIX515e and the PC. The connection is establishing fine. It worked on the older vpnclient. What could be the problem?
tstanik
Level 5
Level 5
You can modify the split tunnelling access list to specify the traffic that should pass through ASA and VPN client. Also try to enable transparent tunneling over UDP.
The solution was the command:
ISAKMP NAT-TRAVERSAL 20
