ASA timeout
I configured a timeout in the 6506 for "Connections" of "24:00:00".
Is the only one configured.
I connect a machine from the outside to the inside and it doesn't close the connection (know stablisehd for 4 days).
But if I dissable the "connection" timeout, the same connection (outside--> inside) is closed in one hour.
I need the connection for several hours, but no permanently.
How I can do it?
thanks. Regards.
Overall Rating: 4 (1 ratings)
That connection variable you are setting is a global connection timeout for all connections through the ASA (timeout conn 1:00:00).
To set a timeout specific to certain traffic/hosts you would have to do the following:
Create a specific ACL for the traffic you wish to set a timeout on (i.e. access-list outside_timeout_in extended permit tcp any eq ssh)
Then a class-map:
class-map ssh
match match access-list outside_timeout_in
Create a policy map to reference the class-map:
policy-map ssh
class ssh
set connection timeout tcp 00:10:00 reset
Then, lastly create the service-policy and apply it to the interface in question:
service-policy ssh interface outside
This rule will basically close any ssh session that is idle after 10 minutes.
