ASA timeouts
Hi;
I configured a timeout in the 6506 for "Connections" of "24:00:00".
Is the only one configured.
I connect a machine from the outside to the inside and it doesn't close the connection (know stablisehd for 4 days).
But if I dissable the "connection" timeout, the same connection (outside--> inside) is closed in one hour.
I need the connection for several hours, but no permanently.
How I can do it?
thanks. Regards.
Overall Rating: 3 (1 ratings)
nathancielieska Tue, 10/16/2007 - 09:54
So if you mean you have configured a PIX/ASA for
"timeout conn 24:00:00"
Then an idle TCP connection will timeout after 24 hours.
The first thing i would ask is if that this connection in reality, is idle for 24 hours. If it is.. is it a well known port? Some applications have their own timeout value.
ie "timeout rpc", "timeout udp"
