ICMP Types
Answered Question
Oct 16th, 2007
Hi all,
I would like to know what is decimal equvalent for ICMP type ttl-exceeded?
Some of them I could use as:
0 - for echo-reply
8 - for echo
11 - for time-exceeded
I know that I can use syntax as:
permit icmp any any ttl-exceeded
but I would like to know what is decimal equvalent for it.
Best regards,
Vladimir
Correct Answer by dominic.caron about 9 years 9 months ago
That's type 3 code 4
Overall Rating: 3.3 (4 ratings)
dominic.caron Tue, 10/16/2007 - 04:46
  • Silver, 250 points or more
I dont think ttl-exeeded type exist.
ttl-exceeded is (TYPE 11,CODE 0)
ICMP message have a code field (8bit) that can give you further info.
Rate all useful post
vnovakov Tue, 10/16/2007 - 06:08
Thanks for quick answer!, Does it mean than that:
will allow only ICMP packets type 11 with code O and
permit icmp any any time-exceeded
will allow all ICMP type 11 with code 0 or 1?
Am I correct?
I have found a way how to add rules as ICMP type and code:
permit icmp any any 11
permit icmp any any 11 0
permit icmp any any 11 1
will apear as:
permit icmp any any reassembly-timeout
Also I'm confused with packet-to-big. By RFC 1885 it is Type 2 Code 0. But under Cisco ISO 12.4:
permit icmp any any 2 0
rule will not apear as:
permit icmp any any packet-too-big
am I wrong about packet-too-big icmp type and code that is used by Cisco?
regards,
Vladimir
Correct Answer
dominic.caron Tue, 10/16/2007 - 07:09
