EIGRP problem
Oct 16th, 2007
Hi experts,
can any one tell me how can we get EIGRP third AD-5 and wat all configuration is needed plz explain it to me in configuration commands if possible.
thanks in advance
Overall Rating: 5 (2 ratings)
saimbt Tue, 10/16/2007 - 03:58
Hi Sandy,
EIGRP will have a third AD-5 whenever there is summarization done by EIGRP.
Pavel Bykov Tue, 10/16/2007 - 04:28
  • Silver, 250 points or more
AD 5 is for summarized routes. Here an example:
For topology displayed in the picture, to have summary route with AD 5 appear on R4, type this on R3:
(config)interface eth0
(config-if)ip summary-address eigrp 192.168.0.0 255.255.254.0
Richard Burts Tue, 10/16/2007 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Pavlo
Yes AD of 5 is for EIGRP summarized routes. And it is local to the router that does summarization. Unless I am misunderstanding something, if you summarize on R3 then R3 will have AD of 5 but R4 will have normal AD for those routes.
Rick
Kevin Dorrell Tue, 10/16/2007 - 07:09
  • Green, 3000 points or more
Rick,
By "normal", is that 90 or 170? I presume it would be 90, wouldn't it?
Kevin Dorrell
Luxembourg
sandy3006 Wed, 10/17/2007 - 01:01
hi all,
yes rick ur right AD-5 will be shown on the router where summarization is done not on R4 i have done that thanks rick i have done theory but i was unable to do it practically thanks once again
regards,
sandeep
sandy3006 Wed, 10/17/2007 - 01:04
hi all,
regards,
sandeep
