VPN Problem
Oct 16th, 2007
I have one proxy with two NICs, an with ip 192.168.2.0 and other with ip 192.168.1.0, the default gateway of the proxy is, ip 192.168.2.115 , router of the ISP. I have an router that connect vpn clients ( pool 172.18.0.0 ), i have route in the proxy, route 172.18.0.0 send for 192.168.2.1, interface this router. My network lan is 192.168.1.0. In my home, my lan is 192.168.1.0 too, i connected vpn client and is mark allow local lan access, but stay without internet. What`s the problem, overlapping networks, how solution for this? In annex, configs of the my router and logs of the my vpn client.
tstanik Mon, 10/22/2007 - 08:10
  • Bronze, 100 points or more
You can do the following:
1. change the ip address of the involved conflicting ip network.
2. increase the global ip pool that is provided by ISP, for the first workaround that I've provided to work.
http://www.cisco.com/warp/customer/707/vpn_pix_private.html
3. for the nat policy, you need to have both ends of the tunnel to nat for it to work, instead of the concentrator you should have either pix or router to nat at the other end.
4. if you have to vpn 3000 concentrator server (not c3002), then link below is appropriate for you:
http://www.cisco.com/warp/customer/471/vpn3k-nat-lan2lan.html
