Validate odbc connections.
Oct 16th, 2007
we?re using a lot of database lookup, when scripts are running. If the DB server is down, the scripts fail. is it possible to check, from the running script, if the odbc connection is down ?
with OnExeption ?
david.macias Tue, 10/16/2007 - 06:32
  • Blue, 1500 points or more
what about using the SQL error branch?
steffenluttge Tue, 10/16/2007 - 12:28
ehhh...
I think the DB subsystem are going in failed, when the ODBC connection fails.. even if there are no scripts running.
Steffen
