VPN on PIX 515e
I have been having some trouble setting up a VPN on my PIX 515e. I tried to use the ASDM but it acts quite fussy about connecting. It will connect and then drop connection and back and forth so I am just going to use the CLI.
I was reading through the PIX CLI manual about setting user groups and so I first created an ACL called DataLan and then I created a Group Policy called Administrator and then tried to apply the ACL to the Group and it wont take:
hostname(config)# group-policy FirstGroup attributes
hostname(config-group-policy)# vpn-filter acl_vpn
Any ideas?? Please help!
acomiskey Tue, 10/16/2007 - 05:56
  • Green, 3000 points or more
David,
Could you elaborate on "it won't take". The command won't go in or it's not working as you want it to?
I think you may be missing the word "value" in your commmand.
#vpn-filter value DataLan
Sorry, when I add the DataLan argument it does not recognize this command. I copied this format directly out of the manual.
I want to make sure I have this whold process right before I continue, hopefully you can help.
I believe that I have to make ACL's, apply them to groups and then make users part of these groups to grant them specific access. Is this right?
Thanks for any help.
acomiskey Tue, 10/16/2007 - 06:10
"Sorry, when I add the DataLan argument it does not recognize this command. I copied this format directly out of the manual."
-You just missed the word "value" in your command.
"I believe that I have to make ACL's, apply them to groups and then make users part of these groups to grant them specific access. Is this right?"
-The vpn-filter is applied to a group policy. The group policy is then applied to a specific vpn tunnel group or user account.
