SSID broadcast
Oct 16th, 2007
Configure multiple WLANs using 4400 WLC. All WLANs ssid broadcast are disabled. The guest WLAN does not have secuirty enable. It appears the SSID for the guest access is still broadcast. Any suggestion? Thanks.
Scott Fella Tue, 10/16/2007 - 06:44
If you do not have the check box enabled for broadcast, then it will not broadcast. Maybe make sure you apply it again and on your wireless client, make sure the profile is not saved, or else it will show up like it is broadcasted.
For ease of guest deployment, you should broadcast the ssid... just my opinoin!
davidm101 Tue, 10/16/2007 - 10:44
Check the WLC configuration and noticed the broadcast ssid is not disabled. I did the config change using WCS. It looks like the WCS did not propagate the change to the WLCs even I did the save and reboot. Thanks.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
