Warning message
Getting all devices to be listed by host name and not IP
Oct 16th, 2007
When I go to DFM -> Device Management -> Device Details I see some devices listed by Ip and some listed by full DNS name. What may be causing Cisco to not see all devices in DFM listed by DNS?
g_curuchaga Tue, 10/16/2007 - 07:27
Hello, You need define a host file in the machine to resolve the IP for name.
regards
Guillermo
brandon.n Tue, 10/16/2007 - 07:44
Even if the devices are added in DNS? Shouldn't they resolve via DNS?
g_curuchaga Tue, 10/16/2007 - 08:06
NO, you need create the host file to resolve name.
regards
Guillermo
jedavis Wed, 10/17/2007 - 14:35
It is not true that you need a hosts file. I do not use a host file and all of the devices are listed by host name.
Does DCR have the devices that are listed by IP address correctly identified?
Martin Ermel Wed, 10/17/2007 - 23:22
  • Blue, 1500 points or more
that's right, you just need to have the IP address resolved. The problem is that DFM does not update its information when once it has discovered a device by IP. So if name resolution works fine, delete one of the devices with IP and let it be rediscovered. If this is ok, do it with the bulk of the remaining IP devices.
