Cannot ping VIP
Answered Question
Oct 16th, 2007
Routing is OK. I can ping from Context out to local and learned subnets, but cannot ping vlan interface on the ACE or the VIP from the sup. So, this means a layer 4-7 issue.
Config is as follows:
class-map match-any VIP-A_Class
6 match virtual-address 1.1.1.3 tcp eq xxx
8 match virtual-address 1.1.1.3 tcp eq yyy
policy-map multi-match VIP-A
class VIP-A_Class
loadbalance vip inservice
loadbalance vip icmp-reply active
loadbalance vip advertise active
interface vlan 3
ip address 1.1.1.2 255.255.255.248
service-policy input VIP-A
no shutdown
Other info:
There is an operational reachable server in the group.
The Admin context does not have an interface on VLAN 3, only allocates it to the context.
I have looked into route health injection but don't think it is relevant to this, correct me if i'm wrong?
If you require more info, please let me know.
Correct Answer by Gilles Dufour about 9 years 9 months ago
you do not have a 'loadbalance policy ' in your multimatch policy. So I don't see how this policy can be up.
Except that your config is ok.
I'm using the same in the lab and it works.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Tue, 10/16/2007 - 23:27
  • Cisco Employee,
Gilles.
danger_mousie Wed, 10/17/2007 - 01:32
I don't really need an L7 policy for this particular group, so wasn't going to add it in. I can add a dummy one in if necessary. This is the reason I cannot ping it?
Gilles Dufour Wed, 10/17/2007 - 02:47
  • Cisco Employee,
yes you need it.
This is how you assign the serverfarm to the vip.
switch/User1(config)# policy-map multi-match SLB1
switch/User1(config-pmap)# class VIP-250-81
switch/User1(config-pmap-c)# no loadbalance policy SF_Linux4
gdufour-cat6k1#ping 192.168.100.250
Sending 5, 100-byte ICMP Echos to 192.168.100.250, timeout is 2 seconds:
Success rate is 0 percent (0/5)
gdufour-cat6k1#
[Resuming connection 1 to 127.0.0.30 ... ]
switch/User1(config-pmap-c)# loadbalance policy SF_Linux4
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
gdufour-cat6k1#
danger_mousie Wed, 10/17/2007 - 02:52
It's working thanks, just applied it as you were answering. I just put the default class into it.
Yay! Now it's testing time :)
