show tech for 4000 series switch
Oct 16th, 2007
The issue is i have widespread network connectivity problems that seem to be pointing to a switching situation. Our SQL connectivity to 2 highly visible and mission critical applications are seeing hiccups which are basically screwing up data. I think i see some things but i want to get some other feedback.
A few tidbits of information: the counters were cleared a week or two ago.
Should the CPU utilization be this high on a 4000 series without seeing performance degradation as well?
steve.busby Tue, 10/16/2007 - 20:49
From my experience your CPU utilization doesn't look out of line. This document can help you troubleshoot high CPU usage.
Also, what interface(s) are the systems connected to? Because I would look at the speed/duplex on both the switchport and the end device(s). Here's another Cisco document to help you.
