10-16-2007 06:58 AM - edited 03-14-2019 01:25 AM
I am facing below problem:
When we try to check the Real Time Reporting status , it shows the status as not connected. We are not able to view any real time statistics.
Version details are as follows:
Cisco Application Administration - 4.0(4)SR01_Build029
Package: IPCC Express Premium
10-18-2007 05:45 AM
I have seen this before & the two fixes I have seen are are:
1) Check to make sure your JTAPI versions match between Call Manager & UCCX.
2) Server reboots also seems to clear the issue up.
10-18-2007 06:02 AM
I checked the RTR subsystem and Database subsystem.
RTR subsystem was running but database subsystem was stopped.
Rebooting the the server solved the problem
10-18-2007 06:02 AM
Rebooting the server resolved the problem.
12-01-2008 06:15 AM
I am also having this problem with 5.0(2) UCCX Standard. The RTR subsystem is in services, as is everything else. RTR was working fine, and now I get the status: not connected.
Has anyone seen another solution other than a reboot?
