Tranfer issue on CME 4.1
Oct 16th, 2007
When a external call comes and our operator transfers the call to external number ,after the call ends we still see one of the fxo port hung ,till we reboot the router 2821.
please advice.
Paolo Bevilacqua Tue, 10/16/2007 - 11:16
You are running into and fxo disconnect-supervision issue
To understand the problem and fixes, please see:
note 1: unless you are in north america, ground-start and some other things does not apply:
note 2: to get around the problem definitely, used ISDN BRI.
hope this helps, please rate post if it does!
alanhong Tue, 10/16/2007 - 13:00
Thanks for a quick reply
im located in UAE ,Dubai , on etisalat(provider1) it works , but with the new provider Du i face this problem
Paolo Bevilacqua Tue, 10/16/2007 - 13:42
What happens in 99% of the cases, is that you have to configure the exact disconnect tones as described it the document. No other method works.
