tracking available switch ports
osprey3883
I was wondering what tools people are using to track available switch ports, and if you would recommend the tool you are using.
Matt
steve.busby
Level 5
Level 5
Matt,
I use NetMRI (www.netcordia.com) to track switchports. For example it can tell me ports with multiple MAC addresses, unused down ports, and unused up ports.
Steve
Steve,
Thanks for the response, I will check this out.
Matt
If you have Ciscoworks, you can do this with User Tracking reports. I run user tracking for a location, then export it to MS Excel. From there I can sort it by device and port. I also bump the MAC up against another Excel spreadsheet containing the IEEE OUI assignments so that the report includes the NIC mfg. of each device seen on the network.
