DHCP NAT help
Oct 16th, 2007
I am trying to have my router hand out dhcp private addresses and have those natted to the public network. Here is what I have so far. I believe i am missing the acl but have no idea what is would look like.
Current configuration : 878 bytes
version 12.3
hostname Efrain
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.40
ip dhcp pool Chiefs
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.5
ip dhcp pool chiefs
domain-name kcpl
lease 15 23 59
interface FastEthernet0/0
ip address 144.x.x.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 192.168.1.20 255.255.255.0
ip nat inside
duplex auto
speed auto
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
login
mzsrtgzr_cisco Tue, 10/16/2007 - 10:51
hey,
The dhcp process doesn't interfere with nat.
in this answer i'll be assuming that you want to overload the inside addresses.
1st: configure access-list for your "inside"
access-list 1 permit 192.168.1.0 0.0.0.255
2nd: configure the global nat statement:
ip nat inside source list 1 interface f0/0 overload
i hope this helps
gonzalezel Tue, 10/16/2007 - 10:59
thanks for your help, I'm really confused but starting to understand this. How would I go about testing this when all I have is 2 2621xm and a laptop?
mzsrtgzr_cisco Tue, 10/16/2007 - 11:09
laptop --> with cross cable --> router f0/1.
then plug f0/0 with a cross to the other router.
gonzalezel Tue, 10/16/2007 - 11:59
I did this and was able to receive private dhcp but I don't get anything when doing "sh ip nat translations" on the router, is this correct?
